Disables the replacement of DiffServ code points in packets transmitted by the switch.
port_list | Specifies a list of ports or slots and ports on which Diffserv replacement will be disabled. |
all | Specifies that DiffServ replacement should be disabled for all ports. |
qosprofile | Disables DiffServ on a QoS profile. Note: If this
option is not specified it will disable DiffServ replacement on
all qosprofiles.
qosprofile | Specifies the QoS profile number. |
The DiffServ replacement feature is disabled by default.
N/A.
The following example disables DiffServ replacement on selected ports:
disable diffserv replacement ports 1:2,5:5,6:6
This command was first available in ExtremeXOS 11.0.
The qosprofile keyword and qosprofile variable were added in ExtremeXOS 16.1.
